Gary C Posted April 22, 2003 Share Posted April 22, 2003 Trying to find out how to get a gable roof to intersect another gable roof perpendicular. If I create two roofs perpendicular to each other, how do you intersect the two and show the vallies, etc.. Quote Link to comment
Robert Anderson Posted April 22, 2003 Share Posted April 22, 2003 Draw the roofs from a single "T"shaped poly. Set the ends of the T crossing and stem to be gable faces. Quote Link to comment
mkin Posted April 22, 2003 Share Posted April 22, 2003 Gary, I may be the only one that needed this info, but I never knew how to "Set the ends" until someone pointed it out. (I guess I never was a very thorough reader) After using the "Create Roof from Poly" command select the roof by clicking it anywhere -Then put your mouse directly over the little black square that corresponds to the desired gable end of each roof plane and click it. You'll get a dialog box and all you need to do is check the "Gable End" check box. Matt Quote Link to comment
