problem importing multiple design layers
2 answers to this question
You can do this using the Create New Design Layer workflow.
  • Rather than selecting Create New Design Layer, select Import Design Layers instead.
  • You can then navigate to the file and select the layer/s you want to import.
  • Check Import Layer objects and you should be fine.
1265677609_Screenshot2021-05-27at08_32_17.thumb.png.4c5b217ab2c6cee6d6bfd7cf19afbec4.png
Do it one layer at a time and save after each import. Then hopefully if you have a crash, you will be able to get a better idea of what may be causing the problems.
Thanks, that’s the procedure that I always use, I’ll try and see if two will import at the same time.
