Bruce Kieffer Posted May 23, 2021 Share Posted May 23, 2021 I cannot get Vectorworks to remember the saved window size when I boot the app. It opens with a shrunk window, I make the window larger the size I want, save the workspace, but on the next booting of Vectorworks the window size is shrunk again. How do I get it to remember the size I want? Quote Link to comment
Bruce Kieffer Posted May 25, 2021 Author Share Posted May 25, 2021 VSS says this is an OS bug with two displays. Ok, but it did not happen with my last setup using this same second display. Quote Link to comment
Pat Stanford Posted May 25, 2021 Share Posted May 25, 2021 You are running VW in an emulation mode on first generation hardware. It does not surprise me that there are things that worked on your old hardware that do not work on your current M1. As both VW and the OS have time to be adapted to the M1 architecture they should get better. But from what I understand, the power/$ curve for what you have it pretty strong. Quote Link to comment
Bruce Kieffer Posted May 25, 2021 Author Share Posted May 25, 2021 It's a nice setup I have with the new iMac and the LG 5k display. Quote Link to comment
Bruce Kieffer Posted August 17, 2021 Author Share Posted August 17, 2021 I created a Keyboard Maestro macro to resize the window. It is a workaround. Quote Link to comment
