why won't my walls join
zero
So I use the remove wall break tool, then try and do a simple t-join. It takes 12 seconds to excute ($0.2 charged out to client), and I don't get a clean join. One wall gets a 45 degree bevel, the other wall gets a 90 degree end.
Anyone have any ideas?
win2k pro, matrox g450 (driver about jan03), p3 550, 256 ram, vwa10.1
I also get some very odd results with wall joins in VW 10.1 on a Mac with OS 10.2.4. When auto join is selected sometimes a wall will fly off the page to join to a wall in another county. Three- and four-way joins of walls with varying thickness & angles seem to be impossible. This would be a very nice feature and I hope you guys & girls (at NNA) are working on ways to make it work better.
Peter
  • 2 months later...
Newbie here..Yea, my fingers are already tired of adding walls, then going through the clean-up process a number of times for each juncture. In my preferences, I set up that I wanted my walls to auto-join. Seems to ignore that most of the time, especially when starting off a new wall from an existing one. Also have had those "flying off to nowhere walls" occuring.
...after using ADT for 3 years, I'm not sure if VW is going to come close in the ease of using so-called intelligent architectural objects.
