TomLav Posted May 18, 2021 Share Posted May 18, 2021 Hello. I'm having issues finding a way to show stagedeck height apart from Top/Plan view. As soon as I change for Top view the Text Options parameters disappear. See pictures below. My end goal is to have Text Options (stagedeck height) parameters to be visible with Top view (and also in Viewport). Is there a way to go about this? Quote Link to comment
markdd Posted May 18, 2021 Share Posted May 18, 2021 Data Tags will be the way to go.... 4 Quote Link to comment
TomLav Posted May 20, 2021 Author Share Posted May 20, 2021 Thanks a lot Mark! P.S. came across your webinars on youtube, looking forward checking them out! Quote Link to comment
C. Andrew Dunning Posted June 9, 2021 Share Posted June 9, 2021 On 5/18/2021 at 8:43 AM, markdd said: Data Tags will be the way to go.... And...or...reach out to the developer about a possible feature tweak... 😉 4 Quote Link to comment
C. Andrew Dunning Posted June 17, 2021 Share Posted June 17, 2021 For anyone following this thread... Adding a setting to echo the 2D text block in 3D within the PIO, itself, is quite doable. For decks and plugs, the text block would simply "follow" the 2D location but would be at the "deck top" height: My question: if this capability were to be included for the steps and ramp tool, would you want the text block to be at the height of the top step or ramp top? At floor level? Aligned (raked) with the angle of the steps or ramp? Something else? 1 Quote Link to comment
Mark Aceto Posted June 17, 2021 Share Posted June 17, 2021 I like the "+30" because that's the only text field I'll add vs Dimensioning. That said, I only use it in Plan view. I would think ramps and steps don't need labeling in 3D because the slope indicates direction up/down, and the heights at top/bottom are already labeled, so it would just create visual clutter. Then again: Quote Link to comment
C. Andrew Dunning Posted June 18, 2021 Share Posted June 18, 2021 4 hours ago, Mark Aceto said: I like the "+30" because that's the only text field I'll add vs Dimensioning. That said, I only use it in Plan view. I would think ramps and steps don't need labeling in 3D because the slope indicates direction up/down, and the heights at top/bottom are already labeled, so it would just create visual clutter. Look at all of the potential text items that could be displayed - beyond arrows and their labels. While I, personally, might not use them in 3D, I can definitely see others' valuing that. Quote Link to comment
markdd Posted June 20, 2021 Share Posted June 20, 2021 How about the ability to pick one of the six bounding box faces to align the text with? This could be the case for all stage deck/plug and stage step objects. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted December 3, 2021 Vectorworks, Inc Employee Share Posted December 3, 2021 Totally different question on ramps. If I were to create a report to send to your favorite ramp vendor, which would be the bare minimum to share when ordering a ramp? Height? length? Height & Length? Height & Slope? Do I need to spec the width? Remember, this will likely be with a vendor which whom you've worked with before. I need more than "send me six 4x8's with 2' legs and one matching ramp." Quote Link to comment
