Wilkendorf Posted May 17, 2021 Share Posted May 17, 2021 Hello, I would like to report a problem, maybe there is a solution I have not found. I generate a device with multiple connections, these connections are read from a table with filter connections (name/tag): I have a prepared exel table where I copy these values and put them into a new Connenct CAD table without any filters, I copy this again into the table connections where my device connections are. At first it works, but when I want to move my finished device, this entry disappears. I enter the device values/name from a exel over a fresch table in the same way and it works. Is it possible to copy in connection values via tables? Does the skt_con have a lock for import? Does anybody have any Idea to solve this? I need to import hundreds of numbers into connections of many devices, and if we have the tables why not? . Thank you Quote Link to comment
Wilkendorf Posted May 17, 2021 Author Share Posted May 17, 2021 Hello again, i wanted to show with this screenshot better my problem: Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted May 18, 2021 Vectorworks, Inc Employee Share Posted May 18, 2021 Hello @Wilkendorf, Can you send me a test file showing the problem? It will be easier to see what is going on that way. I suppose that maybe you are setting the values to the wrong place, probably the skt_rec or dev_rec records, while these values should be set to the Socket and Device records. Best Regards, Nikolay Zhelyazkov Quote Link to comment
Wilkendorf Posted May 18, 2021 Author Share Posted May 18, 2021 Hello Nikolay, you have a mail with a test file. Thanks for your help. 1 Quote Link to comment
