Brittney Posted May 17, 2021 Share Posted May 17, 2021 Say I have a small bathroom that is 5'x7'. When I place the int elevation marker, it is too big to fit into the room and does not create the proper viewports, it will create viewports outside of my room. Is there a way to set the elevation parameters in a smaller space? I understand that I can make a section line viewport, but I wanted to create an int. elevation viewport for this space. Thanks! 1 Quote Link to comment
Boh Posted May 17, 2021 Share Posted May 17, 2021 Not sure if there are any settings in the marker tool that will do this for you. A work around might be to edit the interior elevation marker style so that it fits in the room. Quote Link to comment
Tom W. Posted May 17, 2021 Share Posted May 17, 2021 If you double click on the Interior Elevation Marker (or right-click + choose 'Edit') you will enter an edit mode for the section lines where you can drag them into the space + edit them according to what you want to display in the viewports 2 Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted May 17, 2021 Vectorworks, Inc Employee Share Posted May 17, 2021 We made some tweaks for an upcoming service pack that improves how the section cuts are placed in relation to the marker. Until then, the suggestions from @Boh and @Tom W. should help. 2 Quote Link to comment
