Ross McLee Posted May 11, 2021 Share Posted May 11, 2021 Hi, I am laying out some ceiling loudspeakers across multiple floors of a leisure building for a background music, paging and PA/VA system. I inserted them in to my design layer using the speaker tool, and used a brand/model which was similar to the product I am going to choose later. Now I want to change the model, I have tried to select all the ceiling speakers on my current design layer (there are more) and change them using the Select Symbol button in the OIP... but it doesn't work. I select the symbol from Resource Manager and click select, but it looks like only the first speaker object I selected actually changes. I can do it one-by-one just not in bulk. Am I doing something wrong or is this not how the tool should work ? Thanks, R Quote Link to comment
Pat Stanford Posted May 11, 2021 Share Posted May 11, 2021 If you Select all the symbols you can either use the Custom Modification command and click the Replace button at the bottom. Or just select only the symbols and use the Replace button in the OIP. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 11, 2021 Vectorworks, Inc Employee Share Posted May 11, 2021 It should work, but I'm seeing the same issue with the Speaker object. I have entered a bug about it so the issue can be investigated. (VB-178650) Quote Link to comment
