hong Posted February 19, 2003 Share Posted February 19, 2003 Is there a way to control the line weight of batt insulation? Quote Link to comment
TBrown Posted February 19, 2003 Share Posted February 19, 2003 You can control line weights of Batt insulation simply by placing the insulation first then click on it once and change the weight in the attributes pallette. Quote Link to comment
hong Posted February 20, 2003 Author Share Posted February 20, 2003 Thanks for responding. I have tried to change it on attribute palette and it is not working at all. I am using VW 10.1 on OX10.1.2. on G-3 Quote Link to comment
Guest Posted February 20, 2003 Share Posted February 20, 2003 You should be able to change the weight of the item via the attributes palette. Check to make sure the item is not a member of a class that has a different attribute assinged to it. If you have zoom line thickness (File Prefs VW PRefs) turned on, you might want to turn it off or vice versa. The zoom you are at might not be showing the changes based on what you have set for zoom and if this is on or off. Quote Link to comment
hong Posted February 21, 2003 Author Share Posted February 21, 2003 Thanks, Katie. I should have checked zoom in line thickness. Quote Link to comment
