jfmarch Posted February 18, 2003 Share Posted February 18, 2003 I have discovered an odd blip using symbols in walls ste at different Z levels. I am working on a project that has 2 floor levels, a major which is set @ 0'0", and a minor level that is 13" lower. While reviewing the survey model (its a renovation of an existing dwelling), I noticed that all the door and window heads were at the same height, even in walls that were set lower than 0'0". I cehcked these symbols several times, replaced them, and even redrew some of the lower walls- no change. I even reset some of the layer Z infor, just to test, and that didn't work. I thought it odd that, especially with door objects, the sills were not at the bottom of the wall, but hovered at the set Z level of 0'0". I finally noticed in the info pallette a setting for "Height" when a symbol is selected. That did the trick. My question- Is this the way it is supposed to work with walls of different levels on the same layer? Quote Link to comment
rcarch Posted February 19, 2003 Share Posted February 19, 2003 you got it jimbo! Quote Link to comment
