Kevin Posted February 17, 2003 Share Posted February 17, 2003 Using the Note Manager in VW9.5.3, OS10.2.3, it will not accept a note that is longer than 4 lines. Is this normal?! Quote Link to comment
gnkarch Posted February 19, 2003 Share Posted February 19, 2003 Kevin: I feel your pain! I have been a VW user since 8.5 (VA 1.0) and the limitation for notes in Note Manager database has always been approx. 245 characters (can't remember the exact number). the limitation is extremely frustrating. I have several standard notes that I use from project to project that are longer than 245 characters and want to maintain in the note manager database. I have resorted to breaking the note(s) into several smaller notes to work around the limitation. I was hoping that VW would increase the limitation in future versions.. 9, 10, etc. no such luck. Quote Link to comment
Kevin Posted February 21, 2003 Author Share Posted February 21, 2003 Katie or Robert; Is this true? Does VW limit a note to a certain number of lines or characters? Before I invest my time into this part of the progam, I need to know what I am getting into. Quote Link to comment
Guest Posted February 21, 2003 Share Posted February 21, 2003 Each text object for a note or keynote is limited to 256 characters. Quote Link to comment
Kevin Posted February 21, 2003 Author Share Posted February 21, 2003 Thanks Katie. There is another post refering to a limit to the number of notes that the database will hold. Can you please tell me the following: 1. Do Keynotes and Notes use the same database? 2. How many notes can Keynotes hold? 3. How many notes can Notes hold? Quote Link to comment
Guest Posted February 21, 2003 Share Posted February 21, 2003 Keynotes and Notes create different databases, but you can set the Keynotes Pref. to point to a Notes database. YOu can only use the Keynote Preferences pointer for the Text Note and Keynote tools. (this is why you are allowed to point the keynote pref to the notes db) The keynote/text note tools limit you to placing 250 notes in the drawing, however each database can store up to 499 notes with each note no larger than 256 characters. There is no limit to the number of databases you can have, except for room on the hard drive preventing the text files from being created. (text files hold the database information) The keynotes/text notes tools can only be used for one database at a time - the current database Keynote Preferences is pointed to. If you want, you can place 25 notes from DB 1, you can then go to Keynote Preferences and switch to DB 2 and place 10 more notes from this database. You can keep going thru 250 notes on any given drawing. Does that help clarify limitations? I know, it's alot of numbers to keep track of. [ 02-21-2003, 05:40 PM: Message edited by: Katie ] Quote Link to comment
The Hamma Posted February 27, 2003 Share Posted February 27, 2003 the 499 note limit may be true for the data base but try to use the keynote tool when you have more than 250 notes in a database and you will recieve an error Quote Link to comment
Guest Posted February 27, 2003 Share Posted February 27, 2003 Please see the second paragraph stating that in my previous post. Quote Link to comment
Dietmar Lorenz Posted October 31, 2003 Share Posted October 31, 2003 hi katie - is the info below still true for vw-architect 10.5? and please clarify: it's possible to point the keynote prefs to a (general) note db, but not the other way around? if that's true, all db files should be created out of the (general) note prefs, to be able to share them? also, can you help me with the problem that i described in the vw architect forum yesterday? i can't edit/remove a possibly corrupted db from the keynotes prefs. thanks quote: Originally posted by Katie: Keynotes and Notes create different databases, but you can set the Keynotes Pref. to point to a Notes database. YOu can only use the Keynote Preferences pointer for the Text Note and Keynote tools. (this is why you are allowed to point the keynote pref to the notes db) The keynote/text note tools limit you to placing 250 notes in the drawing, however each database can store up to 499 notes with each note no larger than 256 characters. There is no limit to the number of databases you can have, except for room on the hard drive preventing the text files from being created. (text files hold the database information) The keynotes/text notes tools can only be used for one database at a time - the current database Keynote Preferences is pointed to. If you want, you can place 25 notes from DB 1, you can then go to Keynote Preferences and switch to DB 2 and place 10 more notes from this database. You can keep going thru 250 notes on any given drawing. Does that help clarify limitations? I know, it's alot of numbers to keep track of. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted October 31, 2003 Vectorworks, Inc Employee Share Posted October 31, 2003 The note and database length limits are true for VWA 10.5. We are aware that this is a high-priority user wish. If you have edited a notes datebase using a text editor, make sure that the number of notes in the database is the same as the number on the first line of the database. Quote Link to comment
