Biscontin
Dimension angled at specific degree
Hello,
In a 2D drawing, is it possible to set the "Unconstrained Linear Dimension" at a specific angle/degree? It looks like the default is + / - 45°. Check my video and see what I am trying to do.
The final "123" dimension is a copy/paste of what I am trying to get.
Thanks.
7 answers to this question
You can change the default angle snap by double clicking on the icon in the snap palette:  image.thumb.png.c5ae3c4d3c26f2c8038a5ffe60946e03.png
I'm not sure that will get you what you want in an axonometric drawing.I
Posted (edited)
@Biscontin this may not be practical but if you draw the object in 3D rather than 2D then the dimensions will behave the way you want on the design layer. The only issue is the Hidden Line render mode which causes the witness lines to display incorrectly so to generate this I stacked a wireframe viewport on top of a hidden line one:
Not the answer you were looking for I know.
Someone else may have a better idea
Edited by Tom W.
Yes, I meant the "angle from axes" in your screenshot.  Looks like that didn't get you what you're looking for.
@tom W. this is good, it works... thanks! I did as you said and I see the VW error on the witness lines. Could you just guide me how to "stacked a wireframe viewport on top of a hidden line one"?
Thanks thanks.
Thanks thanks.
Cool.
Just duplicate the VP in place so there are two VPs on top of each other. Then for the top VP turn off the class the object is in so just the dimension is visible then change the background render mode from dashed hidden line to wire frame. This will make the dims in the top VP display as solid whilst the object in the first VP underneath remains in dashed hidden line still.
