Ramon PG Posted May 8, 2021 Share Posted May 8, 2021 Ever since styled walls/slabs I cannot make any of them show their components in section when using advanced properties in section viewports. Any pointers on the instructions for this? Quote Link to comment
drelARCH Posted May 8, 2021 Share Posted May 8, 2021 things to check: - viewports settings 'detail level' to be at least medium - class/es of components is/are visible - in advanced properties i attributes tab check 'use attributes of original objects' and maybe other things, but would recommend to check these first 2 Quote Link to comment
Ramon PG Posted May 9, 2021 Author Share Posted May 9, 2021 6 hours ago, drelARCH said: things to check: - viewports settings 'detail level' to be at least medium - class/es of components is/are visible - in advanced properties i attributes tab check 'use attributes of original objects' and maybe other things, but would recommend to check these first Thanks, your help and lots of tweaking set it right. And... how do you get concrete stairs to show their material in section? Other tan selecting "concrete" in the stair settings I don't see where the actual sub-class components show. Quote Link to comment
