matteoluigi Posted May 5, 2021 Share Posted May 5, 2021 Hi, is it possible to merge more collinear walls in 1 wall-object? cmd+shif+j doesn't work for example. The only solution I actually know is delete all walls and keep one of them. If there are objects inside that wall (e.g. windows, doors,...) pull them out of the wall, after that extend the wall to the wanted length and reinsert all objects you first pulled out of the wall and be happy... But, a single simple shortcut for merging more walls in one wall-object would be great... 2 Quote Link to comment
