cwailes Posted April 30, 2021 Share Posted April 30, 2021 Hello everyone, Why is my stair break showing solid and not dashed? I want to be able to see behind it on the first floor were it breaks. What do I need to change to achieve this. Quote Link to comment
Christiaan Posted April 30, 2021 Share Posted April 30, 2021 Select Stair then: Settings > Graphic Attributes > Stair Break > 2D Dashed Quote Link to comment
cwailes Posted April 30, 2021 Author Share Posted April 30, 2021 Hi Christiaan. I did that and even set the fill to none and it still shows as solid. Is there something else I should be checking/changing? Quote Link to comment
Christiaan Posted April 30, 2021 Share Posted April 30, 2021 Ah yes, this one too: Settings > Graphic Attributes > Stair Break > 2D Solid Quote Link to comment
cwailes Posted April 30, 2021 Author Share Posted April 30, 2021 That didn't work either. Any other ideas? I am stumped, never had this happen before. Quote Link to comment
Christiaan Posted April 30, 2021 Share Posted April 30, 2021 (edited) Hmm, feel free to message me with your file and I'll take a look if you like. Or you could copy paste the stair into a fresh file and post that here if it exhibits the same problem. Edited April 30, 2021 by Christiaan 1 Quote Link to comment
Christiaan Posted April 30, 2021 Share Posted April 30, 2021 (edited) ok, you're talking about one of the lines being solid right? I opened your file in v2020 and it came in fine. Edited April 30, 2021 by Christiaan Quote Link to comment
Christiaan Posted April 30, 2021 Share Posted April 30, 2021 I've sent the file back after saving. Does it still exhibit the same problem? Quote Link to comment
Christiaan Posted April 30, 2021 Share Posted April 30, 2021 (edited) You might also try copying and pasting the stair (to reset it) and see if the new stair has the same problem. Edited April 30, 2021 by Christiaan Quote Link to comment
cwailes Posted April 30, 2021 Author Share Posted April 30, 2021 Let me check. What I am actually trying to achieve is that the stair after the break be transparent so I can see items beneath it, such as cabinets, countertops, etc. Quote Link to comment
Christiaan Posted April 30, 2021 Share Posted April 30, 2021 (edited) Ah right, in that case set this Fill to none and Pen to a dashed line: Settings > Graphic Attributes > 2D Treads > 2D Dashed Edited April 30, 2021 by Christiaan Quote Link to comment
