LeeElston Posted April 30, 2021 Share Posted April 30, 2021 I have been using cloud services to render drawings as pdf's and this appears to work fine and free up my machine whilst it's doing it. However, if I try to export as an image file it doesn't seem to do the re-rendering, just create an image from the viewport in whatever state it happens to be in.. Am I missing some setting or can you not the cloud services to produce high quality image files? Attached is sample of what has been generated... Quote Link to comment
Vectorworks, Inc Employee inikolova Posted May 3, 2021 Vectorworks, Inc Employee Share Posted May 3, 2021 Hi @LeeElston, On the Publish dialog, select the item that you want to publish to an image and click the Options button. In the dialog box that appears, make sure the checkbox to Update visible out of date viewports is enabled. Please let me know if you continue to have troubles. Best regards, Iskra Nikolova 2 Quote Link to comment
