napwszzm Posted April 30, 2021 Share Posted April 30, 2021 Hello, I need help or advices on how to save a cabinet to library properly. I have done many tastings, but failed to get the expected result. So I come here for help. I created a custom cabinet with drillings, and saved that unit as a symbol named BCxx in the picture 1. And then, I tried to open the BCxx cabinet in the current and a new VMX file, all the drillings are missing. I have to manually apply them back by hand. This means all the saved drillings are missing. It's just a blank box now. It seems Interiorcad lost the connection to library components. Do I have to reinstall Vectorworks and Interirocad? It will be much appreciated if someone can help. Regards, Nap Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted April 30, 2021 Vectorworks, Inc Employee Share Posted April 30, 2021 You need to use the cabinet tool and then choose the saved preset from the mode bar. It doesn't work if you insert from the resource manager. Quote Link to comment
napwszzm Posted May 3, 2021 Author Share Posted May 3, 2021 On 5/1/2021 at 5:09 AM, Stephan Moenninghoff said: You need to use the cabinet tool and then choose the saved preset from the mode bar. It doesn't work if you insert from the resource manager. Hi Stephan, Thanks a lot for your solution. 😀 I still have the "drag and drop" concept/habit with me when using Ineterirocad, so it takes me sometime to get used to the new way of using Interiorcad. Thanks a lot for your reply again. Regards, Nap Quote Link to comment
