J Parkin Posted January 13, 2003 Share Posted January 13, 2003 Hi all can someone help me with this problem. For some reason the automatic classing function has stopped working for me. everything except dimenstions end up on whatever the active class is. Its driving me mad.... Ive looked in the manual but had no luck..... thanks Jason (PC based VW architect 9.52) Quote Link to comment
Guest Posted January 14, 2003 Share Posted January 14, 2003 Some objects will go into the default class. Also, if the class was deleted, those objects in that class will go into the none class. Please note, there is a folder of symbols called Non-Class that has the same symbols as the rest of Object Libraries but without thier pre-set class assignment. What type of objects are you inserting into the drawing that are not classing correctly? Quote Link to comment
J Parkin Posted January 14, 2003 Author Share Posted January 14, 2003 Everything is going into the default class, Even walls doors windows etc....Stuff that should automatically assign itself to the correct class Quote Link to comment
Robert Anderson Posted January 15, 2003 Share Posted January 15, 2003 Are you using the objects from the Object Browser or the objects from tools? Quote Link to comment
J Parkin Posted January 15, 2003 Author Share Posted January 15, 2003 From the Tools... Im guessing somehow ive changed a setting that allocates classes Quote Link to comment
