javitojavitojavito Posted April 29, 2021 Share Posted April 29, 2021 Hi all, I've been testing Edu version of Interiorcad extensively for the last couple of weeks and @Stephan Moenninghoff has been super helpful is solving my all queries. I have three issues that I am trying to figure out yet: - Performance: I made a test with 8 cabinets, 12 drawers and a couple hundreds cabinet connectors (cabineo and screws) and things are slowing down. Testing in in a i7 with windows, 16Gb and Radeon RX 580 8Gb. Full quality OpenGL and shadows. File is now 130 Mb. Which system would be recommended for these type of files? Maybe there are some optimization routines that should be applied? - connector placement: I have nested groups for different cabinets so when double click I can isolate parts of the model and work faster. I found an issue when inserting cabinet connectors on nested groups, the connector wont align properly on the grid. See first image below. Funny thing is that if I copy the cabinet to an empty document it will allow me to insert the connectors as expected. See second image. So I ended coping and pasting cabinets back and forth to insert connectors. - Coincident duplicates. When creating cutting list I am getting far too many connectors and fittings counts. I checked that there are no elements one of top of each other but there might slip out something when cutting and pasting. Is it possible to remove coincident duplicates in order to get those listings correct? In summary I find Interiorcad intuitive and powerful but before presenting the tool to students next semester I would like to check that it would simplify their design workflow and reduce errors when cutting things on the CNC. Many thanks! Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted April 30, 2021 Vectorworks, Inc Employee Share Posted April 30, 2021 Can I have a look at your file? I have an idea what's happening. Quote Link to comment
javitojavitojavito Posted April 30, 2021 Author Share Posted April 30, 2021 Thanks Stephan, I just send you the file via wetransfer. Thanks again! 1 Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted May 1, 2021 Vectorworks, Inc Employee Share Posted May 1, 2021 On 4/29/2021 at 11:18 AM, javitojavitojavito said: - Performance: I made a test with 8 cabinets, 12 drawers and a couple hundreds cabinet connectors (cabineo and screws) and things are slowing down. Testing in in a i7 with windows, 16Gb and Radeon RX 580 8Gb. Full quality OpenGL and shadows. File is now 130 Mb. Which system would be recommended for these type of files? Maybe there are some optimization routines that should be applied? I would like to have a look at that file as well please. From what you are describing, it does not sound like it should be slow. I might find out why it seems to perform poorly though. On 4/29/2021 at 11:18 AM, javitojavitojavito said: - connector placement: I have nested groups for different cabinets so when double click I can isolate parts of the model and work faster. I found an issue when inserting cabinet connectors on nested groups, the connector wont align properly on the grid. See first image below. Funny thing is that if I copy the cabinet to an empty document it will allow me to insert the connectors as expected. See second image. So I ended coping and pasting cabinets back and forth to insert connectors. This issue should be fixed in the upcoming service pack. Thanks for reporting! On 4/29/2021 at 11:18 AM, javitojavitojavito said: - Coincident duplicates. When creating cutting list I am getting far too many connectors and fittings counts. I checked that there are no elements one of top of each other but there might slip out something when cutting and pasting. Is it possible to remove coincident duplicates in order to get those listings correct? I am not aware of a script to check coincident duplicates but I checked your file manually and the counts seems ok. I also created an empty file and inserted the same connectors you used and the count seemed to add up. Did you see this in the file you sent me? On 4/29/2021 at 11:18 AM, javitojavitojavito said: In summary I find Interiorcad intuitive and powerful but before presenting the tool to students next semester I would like to check that it would simplify their design workflow and reduce errors when cutting things on the CNC. That is our mission and it should do just that 🙂 2 Quote Link to comment
javitojavitojavito Posted May 7, 2021 Author Share Posted May 7, 2021 Thanks Stephan apologies for the delay in responding. I think the issue was caused from copying and pasting between files all the time. I updated my EDU vectorworks to the latest version and things seem to be working regarding duplicates now. Also replicated the same design without copying and pasting cabinets between files and my file is not bigger than 50mb. Made a bunch of custom connectors and seems to be working fine now. The problem with the connectors and the groups seems to be just when the cabinet is nested in at least two groups if you keep a single group structure connector placement seems to be working well. BTW I found that the purge command has a coincident duplicate option. Handy if you have placed the same connector on the same place twice! Thanks again! So far I am enjoying it, it requires a bit of structure but is far better solution than we have used in the past! Quote Link to comment
Vectorworks, Inc Employee Stephan Moenninghoff Posted May 8, 2021 Vectorworks, Inc Employee Share Posted May 8, 2021 17 hours ago, javitojavitojavito said: Thanks Stephan apologies for the delay in responding. I think the issue was caused from copying and pasting between files all the time. I updated my EDU vectorworks to the latest version and things seem to be working regarding duplicates now. Also replicated the same design without copying and pasting cabinets between files and my file is not bigger than 50mb. Made a bunch of custom connectors and seems to be working fine now. The problem with the connectors and the groups seems to be just when the cabinet is nested in at least two groups if you keep a single group structure connector placement seems to be working well. BTW I found that the purge command has a coincident duplicate option. Handy if you have placed the same connector on the same place twice! Thanks again! So far I am enjoying it, it requires a bit of structure but is far better solution than we have used in the past! That sounds good. Thanks for confirming! Quote Link to comment
