A quiero with offset command in create object from shape
Rishie
Hi,
I'm creating a fence from a line and I want the line to be on the left edge on the fence. i.e, the fence should be inside the line touching it at the left side of the fence.
Is there a way to achieve it while creating the fence from "objects from shapes command".
Also how the offset works here, I've tried all the offset command but the objects is place exactly on the line, I don't think the offset command performs here.
Can anyone here me with this?
1929630152_Screenshot2021-04-28at8_41_28AM.thumb.png.fda14a376209ab669bf7d64caa96e6a5.png
1 hour ago, Benson Shaw said:
Can you offset the source line? Prior to the Create Objects command,  So that ctr of fence is placed correctly.
Yes you can manually offset the path yourself before running the command if you know the width of the fence/railing but be good if the auto-offset worked given it's there as an option... like with Walls
