Lilly rauto Posted April 28, 2021 Share Posted April 28, 2021 How can i make my house dark when converted to pdf? Quote Link to comment
Pat Stanford Posted April 28, 2021 Share Posted April 28, 2021 If you lines are a color other than black, change the color to black. You can also select the lines and increase the line thickness. Usually something between 10 and 40 mils (.25 to 1 mm) is a reasonable line weight. If you are using a Line Weight of 2 mils it will be like a hairline and will show very light in PDF and possibly not print at all. 2 Quote Link to comment
