Can't drag walls longitudinally
I'm working on a document converted to VW 10.0.1 from VW 9.5.2. I am now unable to drag my walls longitudinally. Further, although I have not checked auto join in VW preferences, when I drag them laterally they remain joined at the corners (i.e., the wall to which they are joined is shortened or lengthened). I have not noticed this problem until several hours into working on this file, and I suspect it has just cropped up since I've been dragging walls in the normal way up to this point without noticing any odd behavior.
Win2000
P4 2G, 768 MB RAM
[ 01-05-2003, 01:27 AM: Message edited by: P Retondo ]
This is a feature, not a bug, at least if I understand you correctly. Specifically, the new "connected walls" feature. To turn off this feature, select the arrow tool (2D selection cursor) and disable the rightmost button in the mode bar. Now you will be able to free-drag walls and they will not stay connected.
