P Retondo Posted January 5, 2003 Share Posted January 5, 2003 I'm experiencing the following: -Insert a new window or door -Edit in the PIO info palette -Edit a second time, and the window disappears. The information for the object still remains in the info palette. The window and door tools no longer function at all. This behavior is not consistent. I can always quit the program and open it, which gets me at least one successful window install and edit. Sometimes I can go on for a while entering and editing windows and doors, but eventually the problem recurs. More often than not, it happens upon the second edit of a PIO door or window. Am I the only person who has experienced this problem? This is not a class visibility problem! After reinstalling my 10.0.0 upgrade, and a fresh 10.0.1 update, the problem persists at every stage of installation. VW 10.0.1 Win 2K P4 2GH, 768 MB RAM geforce 3 ti [ 01-04-2003, 11:51 PM: Message edited by: P Retondo ] Quote Link to comment
P Retondo Posted January 5, 2003 Author Share Posted January 5, 2003 It gets worse. Now my wall, which had received the disappearing door, will not accept a new door in the same location. It keeps popping out every time I attempt to move it to the correct location. It's as though the invisible entity still exists inside the wall. So I have to delete the wall entirely to get things to work. I've posted on this issue more than three weeks ago, with no response from technical support. I recently got email from a software engineer asking for a file displaying the problem, but since all files new and old display the problem, I just had to pass on the above info. Either I have a bad copy of VW 10, or something strange is going on, or I'm the only person who has upgraded to 10 that uses window and door PIO's (just kidding on the last one, I hope) because no one could work for more than a day or two under these conditions. This is the second upgrade with VW I have been unable to use because of program problems (9.5 had broken walkthrough tool). Hate to say it, but after using MiniCAD/VectorWorks for almost ten years, I can see light at the end of the tunnel and it looks like a competitor's software. Quote Link to comment
Robert Anderson Posted January 6, 2003 Share Posted January 6, 2003 We recently uncovered a bug if you were using a PIO within a symbol and the symbol had a single quote in its name. If this is the case, eliminate the single quote. Quote Link to comment
P Retondo Posted January 6, 2003 Author Share Posted January 6, 2003 Robert, Thanks for the reply, but this is not the case. I'm talking about a really basic problem. Create a new document, create a single wall, place a single window or door in the wall using any PIO tool, edit that object twice -> it disappears and all the window and door insertion tools are disabled until the program is restarted. Quote Link to comment
Guest Posted January 6, 2003 Share Posted January 6, 2003 I am on Win2k and tried this and I cannot duplicate it. It happens in new blank documents, or are you using a template? Quote Link to comment
Robert Anderson Posted January 6, 2003 Share Posted January 6, 2003 P Retondo, I agree that this is a basic problem, however I'm not able to reproduce it (I'm on a Mac system at the moment). I've got our head "window and door guy" on the case. I'm expecting he will respond to this topic with some info later this morning. Quote Link to comment
P Retondo Posted January 6, 2003 Author Share Posted January 6, 2003 Katie and Robert, Thanks for the responses. Katie: I don't use templates. Just opened a new document using ctrl+N. I would not be surprised if you find it difficult to reproduce the problem, since no one else has reported the difficulty so far (to my knowledge), therefore it seems likely that there is something about my system that is causing the problem. Could it be a conflict with my still-installed versions 8.5.2 or 9.5.2? Could it be a defective copy of 10.0? Quote Link to comment
Robert Anderson Posted January 6, 2003 Share Posted January 6, 2003 P Retondo, despite the fact that this may be caused by a setup, why don't you email me a copy of a document that illustrates this problem? Mail to: randerson@nemetschek.net Quote Link to comment
P Retondo Posted January 7, 2003 Author Share Posted January 7, 2003 Robert, I sent a file to you containing a wall which once had a window in it, now disappeared. I've also sent it to KID at NNA, who had contacted me asking for a sample file regarding this problem, and to whom I have sent a few emails previously. Thanks for your efforts! Quote Link to comment
P Retondo Posted January 8, 2003 Author Share Posted January 8, 2003 I think Win2000 can be removed as a suspected cause of this problem. I tried installing my copy of VW 10.0.1 on a machine with WinXP, and the same problem of disappearing windows/doors occurs. Quote Link to comment
Guest Posted January 8, 2003 Share Posted January 8, 2003 Just out of curiosity, could you try unchecking the "On Schedule" box in the Data Settings group, and see if you still have any problems with the objects disappearing? Quote Link to comment
P Retondo Posted January 9, 2003 Author Share Posted January 9, 2003 Charles, Since the problem is intermittent (occurs more often than not, but not always), I can't be sure - but with "on schedule" unchecked, I have been unable to reproduce the problem at this point. Quote Link to comment
