Round Walls extruded as straight lines
Dylan B
Hi all,
I cannot figure out why my round wall tool/round objects are being extruded and appear as octagons in 3D mode? is this something that needs to be adjusted in the preferences?
When looking at Top/Plan view they appear as a curved line/object, but when I extrude them they turn into straight lines. I've tried using the arch tool, polyline arch tool, and round wall tool. Creating object and adding them to surface then extruding as well as adding them together as 2 separate objects.
1965653506_Screenshot(19).thumb.png.06f21cd5b898feea65014d86a80a8fdd.png718363216_Screenshot(18).thumb.png.4f9107d954d15b7e53452a8fb97ee82e.png
1 answer to this question
View > Rendering > OpenGL Options
Your Detail is probably set to Low.  Every setting above Low will decrease the angle between the facets.
There is also a short cut to this setting in the Render Mode pulldown in the top bar.  (Looks like a teapot).
