JennaFoxley Posted April 22, 2021 Share Posted April 22, 2021 Hi everyone, I've drawn several spaces using the spaces tool and assigned zones to them, but when i run my data visualization its only colouring in some of them. Can anyone think why this is? Also is there a way to edit already assigned zones. Can't seem to find much on this subject matter Quote Link to comment
Pat Stanford Posted April 22, 2021 Share Posted April 22, 2021 Probably the zone data you are using for the spaces is not exactly the same as the zone data you are using in the Visualization. Can you post a screen shot of your Visualization setup? Quote Link to comment
JennaFoxley Posted April 22, 2021 Author Share Posted April 22, 2021 I've attached a few screenshots below. It looks like my 'Proposed shopfront types 2021' zones have gone into multiple assigned zones, as theyre in both |Assigned zone 4 and Assigned zone 3. But i'm not sure where you can control what assigned zones they go into. When i apply the data visualisation from 'Assigned Zone 4' it only highlights some of the spaces and not all of them even though they have the same zones ticked. Quote Link to comment
Pat Stanford Posted April 22, 2021 Share Posted April 22, 2021 It looks like spaces can be assigned to Multiple Zones from the Occupancy Pane of the Space Settings dialog box. I think if you get each space set to only a single zone you might have your solution. Quote Link to comment
JennaFoxley Posted April 22, 2021 Author Share Posted April 22, 2021 Thanks for your help, yes i have also tried assigning them through the settings it still seems to not pick it up. We want to add multiple data to each space, for example in this case i want to tell the space it'll have a certain type of new proposed shopfront but i want to call off what it has now as existing too. Do you know how you can control where the assigned zones go to? I cant seem to figure out how they end up in ' Assigned zone 1 etc.' Quote Link to comment
Pat Stanford Posted April 22, 2021 Share Posted April 22, 2021 Try selecting the Space tool. On the Mode Bar choose the Settings Icon. Make sure that nothing is set for Zone there. Or if you are using Styles for spaces, you will need to check each style and make sure that the Zone is not set By Style and that nothing is set as default. Or it might be something else. Quote Link to comment
JennaFoxley Posted April 27, 2021 Author Share Posted April 27, 2021 I've used the same style for every unit so they should be the same. I've attached a screenshot of my zone settings. It's odd how they all have the same style but the data visualization only picks some of them up. Quote Link to comment
