Windows
When you select the window look at the top of the Object Info Palette.  It should say Window in Wall.  If it just says Window, then your window didn't get inserted into the wall.
Go to a Top/Plan view.  Drag the window away from the wall and drag it back into the wall.  When the wall highlights let go of the window.
If that doesn't fix it post back.  There are other less likely causes.
