Stair tool - top tread dashed in plan
1 minute ago, jeff prince said:
@Chad Hamilton HAarchs Looks like the 2021 stair is not compatible with 2020 😞  I was able to open the file, but due to changes in the stair tool, I can't edit it or investigate what settings are creating the problem.  Hopefully someone with 2021 will help you out.
Thanks so much anyway - much appreciated!
Edited by Chad Hamilton HAarchs
I hope there will be a way to make the Stair look in 2D as you want.
But I think the dashed line would be correct.
With a solid line it would look like there is another tread and elevation difference,
like for the real treads. So I think it is ok that it looks different.
I will never get used to that you in US draw the walk line in wrong direction 😃
Edited by zoomer
