stancilent Posted April 22, 2021 Share Posted April 22, 2021 I'm sing Spotlight Numbering to number these cables in ConnectCAD. But having an issue where the actual wire numbers are not resetting and keep starting from where the last cables were, but the yellow tag shows it correctly. Clicking "Clear Cable Labels" does not help in resetting this. Any suggestions on making the blue numbers reset to the number I want? Thanks! Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 22, 2021 Vectorworks, Inc Employee Share Posted April 22, 2021 Hello @stancilent, The value displayed with blue is the Circuit.Number parameter and the value displayed in yellow is the Circuit.Cable parameter. These are two different values, so I suppose that you will have to use Spotlight numbering for Circuit.Number in the same way that you use it for Circuit.Cable. Here is a demo video on how to use Spotlight numbering with ConnectCAD - Also, it would be better if you post your questions in the ConnectCAD section in the forum here, as in there you will get more ConnectCAD users see your questions and answer them. What is more, in there you can look for your question before asking it, as it is very likely that somebody has already asked it and got an answer for it. Let me know if you need additional info on this question. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
stancilent Posted April 22, 2021 Author Share Posted April 22, 2021 @Nikolay Zhelyazkov Thanks so much! I found out the issue and it was something I screwed up that was rather simple. Really appreciate it 1 Quote Link to comment
