Design Layer Data into worksheet
Posted (edited)
@Pat Stanford
found your script Procedure DesignLayers_to_Worksheet;
i sniffed around to find what variables are used for the additional data and how to get them into the same worksheet. no success...
and as a goody how can the order be changed from top to bottom?
Edited by Thomas K.
I have an almost functional version that is displaying the Name, Description, Elevation and Scale. I don't think the Sorting Order is displayed in the OIP is available via script. The default order that you get the layers is they "inverse" of the stacking order. i.e from the bottom of the list up to the top. We could fix that in the script if necessary.
I have another script floating around about getting tag data that could be incorporated. If I remember correctly, all of the tags have to be read out at once. Do you want the Tag field to show all the tags associated with the layer?
How do you want the final output? Your list above, a space and then the list from the next layer? Or one layer in each column?
Can you post a file showing a few layers with your typical descriptions and tags I can use to test?
