Worksheet - Autofit Column Width
It appears that you can't auto-fit column width, but you can auto-fit row height (if it's any consolation).  Select a row, right click on the row header on the left, and select "Row Height" (or go to Format - Row Height).  There is a radio button for Auto Fit Row Height.  This would also require the cell to be set to wrap text.
Too bad that we can't do that with column width as well.
  • 2 weeks later...
I'd like to fast forward to the part where I can select all columns, and double click on a column edge to auto-fit all columns; same with rows. This is how every other app that uses tables (not just spreadsheets) has functioned for years.
