Space sorting script
Hi all,
I'm pretty new to direct scripting in Vectorworks, but always wanted to learn. As a first attempt I wanted to create a simple script that searches for "spaces" and assigns them to appropriate class depending on Net Area. In my file there is an example that should assign Spaces with area <10m2 to the RED class and rest to the BLUE class.
But, obviously, it fails since I' pretty green in this Area 🙂 Can someone give me a hint, not the solution, something that will help me to write this script?
Space sorting script.vwx
Posted (edited)
@Pat Stanford, thanks
So I think I don't really get the "handle" idea.
I tried to write a similar code for rectangles:
RectCount = int (vs.Count('Rect'))
RectList = []
for i in range (RectCount):
	obj = vs.GetObject((T=RECT))
	area = vs.HAreaN(obj)
	RectList.append([obj,area])
for j in range (len(RectList)):
	if RectList[j][1] < 10.00:
		vs.SetClass(RectList[j], 'RED')
	elif RectList[j][1] >= 10.00:
		vs.SetClass(RectList[j], 'BLUE')
but I don't know how to describe a criteria to search for specified object (e.g. rectangle).
Edited by Grzegorz Krzemien
Posted (edited)
Managed to do this in a different way:
First - same idea, but with Rectangles:
import vs
def RectSort (h):
	area = vs.HAreaN(h)
	if area < 10000000:
		vs.SetClass(h, 'RED')
	if area >= 10000000:
		vs.SetClass(h, 'BLUE')
vs.ForEachObject(RectSort, "T=RECT")
Works great.
I tried to recreate this, but instead of using rectangles, I wanted to use Spaces.
import vs
def SpaceSort(h):
	area = vs.Space_GetNetArea(h)
	if area < 10000000:
vs.ForEachObject(SpaceSort, PON='Space')
But it fails. There is something wrong with criteria I think, but I don't know what.
I couldn't find "Space" object on this page:
https://developer.vectorworks.net/index.php/VS:Search_Criteria#Search_Criteria_Sub_Types
so I assume, I create a criteria in a wrong way.
Try this:
import vs
def SpaceSort(h):
	if area < 10000000:
vs.ForEachObject(SpaceSort,(("PON=Space")))
Like Pat, I'm sort of feeling my way in the dark with Python, but this works for me.
Tried all of these combinations:
vs.ForEachObject(SpaceSort, (PON='Space'))
vs.ForEachObject(SpaceSort, ((PON='Space')))
but all of the fails.
First version gives error that suggests that there are no keyword arguments in vs.ForEachObject(), second and third that syntax is wrong.
GOT IT. The correct combination of quotes is:
vs.ForEachObject(RectSort, "PON='Space'")
Full script:
import vs
def SpaceSort (h):
	if area < 10: #value in m2
	if area >= 10: #value in m2
vs.ForEachObject(SpaceSort, "PON='Space'")
Thanks for help!
