napwszzm
Interiorcad- Am I applying the drilling grid right?
Hello,
I am new to Interiorcad, so can someone show me how to make drilling grid working properly.
Currently I am modeling some kitchen units that using screws to joint the units. When I applied the drilling grids and changed the cabinet dimensions, the quantity and the position of the drillings is not changing properly. I have attached the picture for the problem here:
1. First, I applied the connector and drilling grid that supplied Interiorcad (I did not change anything on drilling position), and made a 720h x 560d x 600 sample box,
2. I changed the cabinet size to 900x 800 x600, the drillings then are at wrong place. I tried different drilling grids, it seems the problem is still there.
Can someone tell me how to apply the drilling grid properly?
Thanks a lot.
Nap
Hi @Marcel Ostendorf and @Stephan Moenninghoff,
Thanks a lot for the information.
I checked the sample screw, I think I did remove the 4mm drilling.
Now, I apply the new screw in the library, and the problem solved.
Thanks again for your help. 😀
Regards,
Nap
