Ed Wachter Posted April 14, 2021 Share Posted April 14, 2021 Hi. I've just created a site model in VW2021. I used 3D polys as the source data. These include some contour lines and corner markers. These polys all have my desired elevations. However, all the elevations on the resulting set model are about 3' (35.741") lower than the elevations assigned to the source polys. Can you think of anything that would cause this discrepancy? I can send to the file if it helps. Thanks Ed Quote Link to comment
Jeff Prince Posted April 14, 2021 Share Posted April 14, 2021 @Ed Wachter post a file in 2020 format and I'll check it out. Quote Link to comment
Ed Wachter Posted April 14, 2021 Author Share Posted April 14, 2021 Jeff, Thank you! File attached. Inside the source data I have a corner marker at each corner with elevations rounded off to the nearest foot. Those elevations are 117', 113', 87' and 92'. When I check the elevations on the site model they're all about 3' lower. I appreciate you taking a look! Ed Site model elevation discrepancies v2020.vwx Quote Link to comment
Jeff Prince Posted April 14, 2021 Share Posted April 14, 2021 (edited) @Ed Wachter I just looked at your model. The elevations at the corners are correct, but I did notice you have placed 3D Loci at each corner that are lower than your site model data. Perhaps you are snapping to those instead? Edit.. I stand corrected. It looks like you may have moved the site model in Z by accident at some point. I took your site model source data into a new file and it generated fine. Your model appears to have been relocated vertically by almost 3'. Changing your 3D appearance from mesh to extruded contours and then back to mesh will fix the problem for you. Edited April 15, 2021 by jeff prince 1 Quote Link to comment
Ed Wachter Posted April 15, 2021 Author Share Posted April 15, 2021 Hmmm. Those loci are snapped to the corners of the site model. They appear to be coincident with the corners of the model. Here's what I'm seeing and why I'm confused. Ed Quote Link to comment
Ed Wachter Posted April 15, 2021 Author Share Posted April 15, 2021 Okay. I moved the model vertically to correct. As I recall, several years ago VW displayed an X, Y & Z locations for a site model in the OIP and then the Z value got removed. I thought it was no longer possible to move a site vertically. It's all better now! Thank you! Ed Quote Link to comment
