buz Posted November 15, 2002 Share Posted November 15, 2002 Trying to use this tool and I get a dialog box saying 'Plug-ins\Common\Data\ID_Symbols.MCD can't be found'. Wanting to use it on some simple door instances from the 'Objects Palette'. Can someone tell me what's going on here? Thank you [ 11-15-2002, 04:01 PM: Message edited by: buz ] Quote Link to comment
buz Posted November 16, 2002 Author Share Posted November 16, 2002 Ok - so I have been having more and more trouble with this as well as other things - wish I knew what was so haywire. The ID Tool will not ID a door. A door from the ObjBrowser will not cut walls. And export image file (jpeg) will only export the lower right corner of the drawing. (8.5x11 portrait) So .... I suppose I should have three postings?????? [ 11-16-2002, 11:53 AM: Message edited by: buz ] Quote Link to comment
buz Posted November 16, 2002 Author Share Posted November 16, 2002 Updated to 9.5.3 and the ID tool is working again and the export>image file>jpeg is just fine. Haven't checked the OBjBrowser door issue yet. Couldn't see coming back for another post re the doors - so checked - and it to is working. Admin/Mod: delete this topic/thread if you like. Quote Link to comment
Guest Posted November 18, 2002 Share Posted November 18, 2002 When a door or window isn't cutting a wall, make sure the "Enable Wall Insertion Mode" is turned on when you click on the 2d Selection Tool. THe image export thing - you have QT 6. As you have done, 9.5.3 should fix that. If you edited the ID_Symbols.mcd file and didn't run the update text script, you could get that error message too. An update again, should have fixed it. (Information above is for future use) [ 11-18-2002, 09:18 AM: Message edited by: Katie ] Quote Link to comment
