Luc Prairie Posted April 13, 2021 Share Posted April 13, 2021 How to assigne channe number for a Strand Iris 4? Quote Link to comment
Jesse Cogswell Posted April 13, 2021 Share Posted April 13, 2021 Assuming that you are running VW2021, they changed the way that multi-circuit fixtures work. I just dropped in an Iris 4 and for some reason, VW isn't properly showing it as a multi-circuit fixture. After doing a bunch of experimentation, I found that editing the 3D component of the "Light Instr Strand Iris 4" symbol and deleting the C-clamp made the fixture suddenly behave as the 4-cell fixture that it is. Once you've done that, a drop-down in the Object Info Palette called "Edit Cell" will be available. From here, you can select each cell individually to assign color, channel, unit number, dimmer, etc, or select <All> to change values for the entire fixture. 1 Quote Link to comment
