simtav Posted November 6, 2002 Share Posted November 6, 2002 Does anyone use Windoor? If so can you tell me how to draw a window with a slanting top (the glass), as in the 'slanting top' option with complex windows in VW. Thanks ST Quote Link to comment
Guest Posted November 6, 2002 Share Posted November 6, 2002 THere is a Top Pane option in the OIP when you've inserted the window. Select the window configuration style, then scroll down a bit and select the top pane style where it says "Top Pane". When you select "Segment Arch" you can enter in the rise and so forth below that. Quote Link to comment
simtav Posted November 6, 2002 Author Share Posted November 6, 2002 I'm drawing a bit of a blank here Katie. I've used the "top plane" option for the 'complex window' function of VW, but want to know is whether there is a similar "top plane" type option within the Windoor add-on. Thanks ST Windoor 6.0, VW 9.5.1, Windows XP Quote Link to comment
jfmarch Posted November 6, 2002 Share Posted November 6, 2002 What the heck is "Windoor"? Is that a seperate program by NMA? Quote Link to comment
simtav Posted November 7, 2002 Author Share Posted November 7, 2002 It's an add-on for designing custom windows/doors http://www.nemetschek.net/addons/arch/windoor6.html Quote Link to comment
Guest Posted November 7, 2002 Share Posted November 7, 2002 OH that... That's made by the Austrailian or New Zealand distributor. We don't have a copy of that. You may want to contact one of them at OzCad for more information. www.ozcad.com.au Quote Link to comment
