Grzegorz Krzemien Posted April 10, 2021 Share Posted April 10, 2021 Hello, I have some problems with Tile fills in my slabs. I tried to create own Tile fillings for my slabs, but they all fail in sections. As I noticed even built-in Tile fills do not work properly - they are moved, not aligned etc. I tried many combinations of settings, but still either I am missing something or it just does not work. Picture and file in attachment. Slab test.vwx Quote Link to comment
Tom W. Posted April 10, 2021 Share Posted April 10, 2021 I can't open your file because I'm on VW2020 but I would check your 'Edit Tile Settings': do you have 'In Wall' + 'Fit to Wall' enabled? The former rotates the tile to the orientation of the wall/slab/roof component + the latter scales it to match the component's thickness Quote Link to comment
Grzegorz Krzemien Posted April 10, 2021 Author Share Posted April 10, 2021 @Tom W. Yes I have 'In Wall + Fit to wall' enabled. All of my Tile fills work fine in walls, but fail in slabs. Funny thing is that the same file in VW2020 works fine. Slab test v2020.vwx Quote Link to comment
Tom W. Posted April 10, 2021 Share Posted April 10, 2021 Yes you're right works fine in the VW2020 file. You need someone else to test it in VW2021. Don't believe I've seen any other posts about this happening in VW2021... Do the tiles work ok on roof components? Quote Link to comment
Grzegorz Krzemien Posted April 10, 2021 Author Share Posted April 10, 2021 Tiles in roof work fine. I even tried to reinstall my VW21, so now I'm working on a clean software. This affects only slabs. Quote Link to comment
