Chris Busch Posted April 9, 2021 Share Posted April 9, 2021 I've had this issue for a while, and have tried to solve it different ways, but wondering if it's not just a bug. When I use the clip cube with Open GL or Renderworks, I often get inconsistent texture clipping. It's seems like the texture plane is outside the clip cube within a different coordinate grouping, and it wants to show the clipped surface highlighted in red as if it's at the edge of the clip cube.. These a re Hybrid symbols, which I'm sure has a lot to do with it, but I've set all of my objects to be centered on the symbol locus, and zeroed out the coordinates of the polygons within the extrusions. The texture is applied to the Top texture surface, as these are graphic objects with different content on each side. and I've set the extrusions with a fill color that's not set by class (if that matters). Any help would be much appreciated! Thanks, -Chris Quote Link to comment
Chris Busch Posted April 13, 2021 Author Share Posted April 13, 2021 (edited) So I just figured out that it only affects objects that use textures with included transparency. My usual workflow had been to create a texture with a PNG and use the alpha channel as the transparency mask, and to put that on the Top surface of my graphic object to simulate cut vinyl lettering. I would then rely on the color fill of the object to create the background in order to maintain consistency as I change the colors to match the walls. This has its own problems, but I haven't found a better way to create cut vinyl or oddly shaped graphics. I've never quite figured out how decals are supposed to work, as they don't render in OpenGL as far as I know. Anyway, for now I'll simply avoid this workflow, but it does seem like the way it interacts with the clip cube is a bug. Thanks, -Chris Edited April 13, 2021 by Chris Busch 1 Quote Link to comment
Vectorworks, Inc Employee JustinH Posted April 15, 2021 Vectorworks, Inc Employee Share Posted April 15, 2021 good find. bug about transparency and clip cube logged in Jira VB-178081 clip cube cap wrong on extrude with top part having transparency... 1 Quote Link to comment
