Alessio
Showing Object dimension in Object info menu
Hi,
I am wondering if it is possible to show the output value of a math node in the object info shape menu like on the image below.
If it is, can someone tell me how to do it?
Hi @Alessio,
that is possible. Simply use the Marionette.WidgetType.TextStaticParam in the OIP part (see also the developer wiki)
and change the value shown by using self.Params.Something.SetValue
For example:
FileName = Marionette.OIPControl( 'File name', Marionette.WidgetType.TextStaticParam, '<None>' )
self.Params.FileName.SetValue( str(os.path.basename(vs.GetFPathName())) )
Regards,
Antonio
Hi @Antonio Landsberger ,
Thank you for your supply.
I am not realy sure how to do this. I am quite new at marionette.
I want to create it with a input like the image.
i hope you can help me out.
Regards,
Alessio
If you only want to see the values that are coming out of a node, use the "Print Debug" node.
Consider disabling both the time and type in the OIP of this node.
If you are new to Marionette, please check out the online webinar series "Marionette Monday" by Sarah:
@sbarrett Could you please ask the web team to make a YouTube playlist out of the Marionette Monday webinars?
