vassen Posted April 6, 2021 Share Posted April 6, 2021 Hello everyone, Have you guys ever came across this issue while using VW. This is happening to only i need to do a presention to a client. Thanks for your help Quote Link to comment
Pat Stanford Posted April 6, 2021 Share Posted April 6, 2021 This looks like a Snap to Locus problem. A long time ago there was a preference called Snap To Locus which drew the extension lines from Loci to infinity so you could use them as guides and snap to them. More recently (VW2016??) that preference was removed from the VW and Document preferences dialog boxes. The following one line script will toggle that preference on and off. Just copy and paste this into a new blank Vectorscript and then run it from the script palette. SetPref(5, Not(GetPref(5))); 2 Quote Link to comment
vassen Posted April 6, 2021 Author Share Posted April 6, 2021 @Pat Stanford Thanks. Will check how to use the scripts as have never done this before. Quote Link to comment
vassen Posted April 6, 2021 Author Share Posted April 6, 2021 @Pat Stanford It's working thanks Quote Link to comment
Pat Stanford Posted April 6, 2021 Share Posted April 6, 2021 Resource Manager New Resource Script It will open a dialog box asking you to name the palette. It will then ask you to name the script (I often use Bob as a name personally, but others like something that makes sense.) The Script Editor will open. In the pulldown at the top make sure it is set to Vectorscript. Paste the line from above into the editor window. Click the OK button. Double click the script name in the script palette to run the script. 1 Quote Link to comment
vassen Posted April 22, 2021 Author Share Posted April 22, 2021 @Pat Stanford Thank pat. the script did work out. Today when i was working again on the same file it happen to make the same same error again 😞 I try to reuse the script but it's not removing the error this time. Any idea why? Thanks for your help. Quote Link to comment
