Sheet Layer Record?
I know I've seen this before and cannot find it for the life of me.  I'm trying to make a report of all my sheet layer numbers and titles.  What database record/fields would I use for that?
This is not the drawing border option.
Thanks,
Matt
Yes on a index, no on the title block for this particular thing.  That is where I am stumbling.  I have done the above before but without too much explanation I'm not doing that here. Hoping to just get the actual Sheet Layer fields out.
Matt
Try this script. I don't think there is an "automatic" way to get this to update. You will have to run the script again. It is a slight modification of the one found in this thread:
Procedure SheetLayers_to_Worksheet;
{Make a worksheet listing all of the sheet layers in a VW file}
{Lists both used and unused layers}
{The worksheet is named "Layers:"with and appended date}
{Sorts layers in alphabetical order prior to storing in worksheet}
{November 17, 2017}
{Based on a script originally written}
{March 19, 2015}
{November 6, 2020  - Modified to include Sheet Name as well as Sheet Number}
{April 5, 2021 - Modified to not duplicate the sheet number by using Substring}
{ copyright 2021, 2020, 2017,2015,2010, 2008, Pat Stanford pat@coviana.com}
{Licensed under the GNU Lesser General Public License}
Type
	PTS = Structure
	  LayerNum, LayerName :String;
	End;
var	H1, H2:	Handle;
N1, N2:	LongInt;
LayerSort : Array[1..1024] of PTS;
Begin
	H2:=FLayer;
	N2:=1;
	While H2 <> nil do
		Begin
			If GetObjectVariableInt(H2,154)= 2 then
				Begin
					LayerSort[N2].LayerNum:=GetLName(H2);
					LayerSort[N2].LayerName:=GetObjectVariableString(H2,162);
					N2:= N2 + 1;
				End;
			H2:=NextLayer(H2);
		End;
{Add Curly Braces (comment out) the next line to not sort the layers by name}
	SortArray(LayerSort,N2-1,1);
	H1:=CreateWS(Concat('Layers:',date(2,1)),N2,2);
	For N1:= 1 to  N2-1 do
		Begin
			SetWSCellFormula(H1,N1+1,1,N1+1,1,LayerSort[N1].LayerNum);
			SetWSCellFormula(H1,N1+1,2,N1+1,2,Substring(LayerSort[N1].Layername,'[]',2));
		End;
	SetWSCellFormula(H1,1,1,1,1,'Layers in File');
	ShowWS(H1,True);
End;
Run(SheetLayers_to_Worksheet);
