V.DiTunno.Prolights Posted March 30, 2021 Share Posted March 30, 2021 Hello All, I have recently started using Vectoworks, forgive me for my low knowledge of the software. My pupose is to create a moving head. I performed this procedure: I created the three 3d parts (base, arms, and body which also includes a group of lenses). I have assigned the Parts record to the various parts. In the plan I have inserted a drawing on 2d, which obviously reflects the geometry of the symbol. I selected everything and Edit> Create Symbol. I gave the name and done ok and entered the central insertion point. I assigned the Light Info Record and Light Info Record M to this symbol and entered the values. After saving everything, I tried to insert it in a truss but I encountered these problems: Pan and Tilt don't work: I can only rotate the whole symbol, but not the head, arm and base. It is not inserted in the center but misaligned. Can I get some advice on where am I wrong? Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted March 31, 2021 Vectorworks, Inc Employee Share Posted March 31, 2021 After you attached the record did you check the correct checkbox for the geometry in the data pane of the object info pallate? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted March 31, 2021 Vectorworks, Inc Employee Share Posted March 31, 2021 Do you also need a 3D Locus which determines the rotation point for the pan and tilt? 1 Quote Link to comment
