MaltbyDesign Posted March 29, 2021 Share Posted March 29, 2021 I'm using the standing semimetal roof material MT on my model and it appears at half the scale showing seams at 6" apart rather than 12" On walls, it looks like I can scale the spacing up in the OIC - Render tab. But where I've applied this material to a roof, I can't see any way to adjust the scale. Why doesn't the material insert at the correct scale to begin with and is there a way to adjust to the correct scale on the roof? I should note that on one of the wall, adjusting the scale won't work for some reason, despite being identical to the others that dis scale. Thanks for any thoughts on how two fix this. Quote Link to comment
Tom W. Posted March 29, 2021 Share Posted March 29, 2021 I am on VW2020 so haven't used materials yet but assume the issue is to do with the image size of the texture? You can resize it so that the seams are the desired distance apart 2 Quote Link to comment
MaltbyDesign Posted March 29, 2021 Author Share Posted March 29, 2021 @Tom W. Thanks very much. I was looking at that but didn't see the "Set by Image" button. I was also to edit the surface hatch as well. Thanks again. Quote Link to comment
