Selection Behavior
buz
Not sure what is going on here. I have an extruded rectangle which I duplicated an array down the 'y' axis and then took those objects and duplicated across the -x axis. (Pier blocks for a deck) For the layout I needed to delete a few extraneous ones and move a few others. there are about 33 of these objects - all in the same layer and class. A few of the last ones created will not select by clicking nor will they snap to. They will select by dragging a marquee.
At issue is that they will not snap to.
It's probably simple - but I cannot grasp the problem here.
tfyh
Buz
