Michelle B Posted March 25, 2021 Share Posted March 25, 2021 Why do I get the error "Constraint isn't valid" when I try to group items together? Quote Link to comment
0 Pat Stanford Posted March 25, 2021 Share Posted March 25, 2021 Are you trying to group objects that have dimensions to objects that are outside of the group? If you have Associative Dimensions (little green boxes at the ends so that the dimension will update when you move the object(s), you are using a "parametric constraint". It sounds like when you are trying to group the objects, you are breaking that constraint. You can select the Dimension and go to Modify:Edit Constraints and remove the two coincident constraints. Or you can go to Document Preferences, Dimension pane and turn off Associate Dims. HTH Quote Link to comment
Michelle B
1 answer to this question
