if condition with wildcards in strings in python?
just a simple question:
I want to scan object styles.
for example "BA-I-BST-370-230-BFT" contains the letters *BST*
in a worksheet I would write sth like =if('stylename'='*BST'; yes;no)
in Python I tried (running in a foreach-procedure, it has to filter all slab styles, which names contain the letters BST): (i read somewhere that '.+' is the Asterisk equal for python)
if outValue == ('.+BST.+'):
however, it doesn't filter work, why?
Edited by matteoluigi
You’re thinking of a regex string, which still needs a function call in python. Do a web search for python strings. You should be able to find a substring call. I believe the keyword “in” will work as well (“BST” in outValue).
If you want to use regular expressions, you have to use explicitly the module "re", the one handling regular expressions: https://docs.python.org/3.8/library/re.html
Be careful that in regular expressions .+ means "at least one character", which might not what you seem to want.
Edited by Nicolas Goutte
that's to complicated, I solved it with a substring
(of course the letters 'ABB', 'BST' or 'NEU' always appear at the third place in the stylename which has to be separated by '-' 😉)
Quote
ok, outValue, outType, outMap  = vs.IFC_GetPsetProp2((HNDL),'IfcBeam','Name')
Style = vs.SubString(outValue, '-', 3)
if Style == 'BST':
