Steve Riddle Posted March 23, 2021 Share Posted March 23, 2021 I have attached a file with some grasses placed using the place plant tool, beside this I have created a landscape area with the same plants but they do not appear when I choose to show plants in either 2d or 3d? I think the plants within the landscape area have been placed in a distant location from the landscape area but do not know how this came about? Tussock.vwx Quote Link to comment
Poot Posted March 23, 2021 Share Posted March 23, 2021 I think there is an issue with the plant styles you have created - as the landscape area seems to display the predefined plants just fine. I tried also copying the 2d symbol attributes in style settings, but this did not fix the issue. 1 Quote Link to comment
Vectorworks, Inc Employee Tony Kostreski Posted March 23, 2021 Vectorworks, Inc Employee Share Posted March 23, 2021 Hey @Steve Riddle , I played around with your file. Can you share how you created a plant style? That seems to be the culprit and if there is an issue, I'd like to submit a bug on this. Your plants are in fact showing up, just thousands and thousands of meters away. I created a new plant and added it to the existing landscape area with no problem. Tussock-tkostreski.vwx Quote Link to comment
Steve Riddle Posted March 23, 2021 Author Share Posted March 23, 2021 Hi Tony, I created an image prop from an imported file and applied the mask using alpha then created a symbol. I duplicated a plant that I knew would work in the landscape area then applied: Edit Plant Style / 3d graphics /copy from symbol. That didn't work so the second option was to: Edit Plant Style / 3d graphics /edit current graphics then swap the image prop texture and change its size in the object info palette. I have attached a landscape area including the plant style I duplicated. Thanks, Steve Tussock.vwx Quote Link to comment
