  • 1
JMR
Worksheet sorting order / editable stack
For a large worksheet, changing the sorting order is difficult. There is no way to reorganise the order other than removing sorting and then doing it again.
Some kind of editable stack would be great, think of what one can do with sheet layers, for example.
Also the ability so remove/add sorting/summing etc. from several columns at once would be great.
2 answers to this question
It would be great to have a checkbox to apply sort/sum/summarize or not - I often need to turn this all off to check for zero values or other issues, then reapply once I've checked it all.
@JMR I've been using these scripts to make sorting faster.
Just select a cell in the database column you want to sort or not sort and run the script.
Sort Worksheet.vwx
