Using VW architect 2019 SP6 on Mac OS Catalina 10.15.7 | iMac retina 4K 21.5 Inch, 2019, 3ghz 6-core Intel Core i5, *gb 2667 Mhz DDR4 with Radeon Pro 560x 4gb. We use dropbox to share files, this file is locally stored files are less than 50mb in size, so its not a large file.
Issue:
Some of our files are very slow, crash and freeze all the time, we draw 90% of everything in 2D, and use many symbols and groups, My initial thoughts are that perhaps some kind of symbol or object is cause issues within the problem files and since we use the same library of groups/objects this problem object/objects may be causing the issues, is there a quicker way to determine what could be the cause other than trying to check each object?
gytis15
Background:
Issue:
3 answers to this question
