I made a Material Cutting List Worksheet. It works!
  • 2 weeks later...
Do you assign the part ID manually? Does the list include all objects in the file or do you somehow separate objects to be listed from others? Did you find a good workflow for having several cutting lists in the same file, in different sheet layers for instance?
I've been messing around with cutting and parts list type of worksheets a bit with some success, but haven't really reached a conclusion on what the best workflow would be. Things tend to turn a bit messy when you start to duplicate the worksheets and create workarounds on how to include/exclude some objects and so on.
By the way, there used to be a preformatted parts list functionality in previous versions of VW. I gather it's a legacy tool now. I guess using data tags and worksheets is supposed to replace it?
For the Part IDs I assigned a record with an ID field. At first I ent to each object and added the A, B, C, etc. Later I found that those IDs can be added manually inside the worksheet and that is SO MUCH FASTER. The worksheet does filter out some objects. All of that is handled in the worksheet criteria settings. I have make two cut list worksheets on one drawing, but that's as far as I got, and I did not have problems. PM me if you want a copy of my file.
  • 6 months later...
Hi Bruce,
greetings and thnx for sharing your file.
I'm interested to investigate but, atm i only can use VW 2021 (until the German release on 20th Oct.)
Would you please so kind to upload also a VW 2021 Version?
… or does the list include special formulas, which are only available with VW 2022?
Greetings and have a nice weekend
Tobi
4 hours ago, Tobias Kern said:
Hi Bruce,
Tobi
It is a Vectorworks 2022 file, and yes it does use a worksheet function that is new to 2022 and that won't work in 2021.
1 hour ago, Tobias Kern said:
Hi Bruce,
greetings and thnx for reply.
May i ask, which new WS function you use to make the list possible in VW 2022?
Greetings
Tobi
I did have my Cut List working in 2021, but formula needed to define the part's width had to be a nested if then, and it was complicated. 2022 added the median formula, which I knew was the solution from using Apple Numbers, and I had wish listed it with Vectorworks. I changed to using the median formula, and that is why back saving to 2021 won't work.
Also, Vectorworks 2022 essentially eliminates screen plane, and I have always been in favor of that. You can turn it back on in Document Prefs/Legacy 2D, but I suggest that everyone embrace this change and adjust your workflow. Use design layers for designing in 3D, and use sheet layers for annotating. I changed all of my current drawings to eliminate screen plane. I'm using Multi View Planes so I can view my cut list worksheet, which is placed on a sheet layer now, along side a pane with my 3D design layer.
Another welcome change in 2022 is a new worksheet Define Criteria dialog box. It's a HUGE improvement and I don't know if it would back save to 2021.
  • 3 years later...
  • 10 months later...
Hi Bruce,
I am working on trying to incorporate a cut list onto our build drawings for the shop. Having something like this would perfect, something that automatically generates a lists of the components being used.
I have run into a few snags and trying to figure out how to best correct them and incorporate this into my workflow. Here are the problems that I am running into:
  1. All the data being entered into the worksheet seems to be scaled. A 2x4 that is 7'-9" long, is reading as 1/8" x 5/16" x 7-3/4", instead of 1-1/2" x 3-1/2" x 7'-9". At first I thought that this may be a result of the design layer being set to a scale of 1/4", but I get the same reading if I change the design layer to 1:1.
  2. The line items are not collating, if I have a quantity of 3 - 2x4's at 3'-9", each piece is shown individually on it's own line.
  3. This appears to only work on individual extrusions in a drawing. If you try to run this worksheet on a symbol, it will incorporate everything in the symbol, not just what is set to be visible at the time. Is this correct, is there something that I am overlooking?
  4. Is there a way to include angles of what pieces are cut to?
I can upload my file, screenshots, or PDF's of anything, if that will help with understanding these issues.
Thank you,
Brandon
22 minutes ago, b.mechler said:
Hi Bruce,
Thank you,
Brandon
Brandon, It's hard for me to know what is going on. I have some thoughts, but it would be easier if you can send me your file. Do that in a Message to me.
Brandon, I have fixed your worksheet (file attached). Your setup is far different than what I would do. Later on I will create a simple file of your rolling stage dolly to show you how I would do the setup, and try to explain the differences, but I have other things to do this morning.
Most of the issues you were having were caused by the criteria setup. Take a look at the changes I made there. Criteria setup has always been difficult for me. I have asked Vectorworks to make this simpler and more intuitive. As it is now, most of the time it is trial and error for me.
Then I modified your number formatting in the document and worksheet. There's a reason why, and a solution for, the extra " that appears in the height, width, and length columns, but I can't remember the "fix" at the moment. Pat Stanford probably knows how to fix that. The dimensions display correctly when the units are set to inches. Keep in mind that we woodworkers measure in inches, not feet and inches. Carpenters measure in feet and inches.
Also, I suggest you try to using saved views. It's a super fast way to get back to views where you have predefined the visible layers, classes, and other things. It can save you a tremendous amount of time.
The Wizard of Oz v2025.vwx
Brandon, I'm working on the simple file to show you the cut list setup and I noticed that your extrusions on the angled platform are not showing the dimensions we think they should. That's due to how they were created. I will remake them. For rotated shapes, you want to create the shape, then rotate.
Edited by Bruce Kieffer
  • 3 weeks later...
Hey Bruce,
This has been working great! It has taken a little adjusting, but for the better!
There is one thing I am still struggling with. I have been using the worksheet by setting the criteria to the following:
1 - All criteria in this set
2- Layer is Hay Bales
3 - Class is Rolling Base Frame
Using the worksheet set to the above works perfectly in any iteration of layer and class. The problem I am running into is when I add a 4th criteria line, to include more materials. When I do this, it does not detect any objects that meet the criteria and shows nothing in the worksheet.
There are certain classes/materials that do not need to be included in the worksheet, which is why I do not use just the layer for pulling the information.
Is there a workaround for getting the worksheet to be able to select multiple classes in the same layer without including everything in the layer?
Thank you,
Brandon
Brandon,
It's hard for me to know how to make this work without seeing it. My experience is alway trial and error. Try rearranging the order of the criteria. Then try setting the Material to Any. Have you set which material you want to populate the worksheet? Mess around with the settings. If you still can't make it work, then post the file here, or send it to me in a Message.
Yes like @Bruce Kieffer says you need to arrange the criteria so that the classes are in a separate 'any' set i.e.:
    2 - Layer is _____
    3 - Any criteria in this set
        4 - Class is _____
        5 - Class is _____
So read out this would be 'Layer is _____ and Class is _____ or ______'.
Remember:
'All' = 'And'
'Any' = 'Or'
An object can't be in two classes at once.
